Failed inspection again.... (TRY #2)
#31
I really don't have the money for a "high quality cat"... I just need to get inspected now so that I am not screwed over if I get in an accident...
#33
I think before I leave I am just going to give it a try doing everything I can without the cat. I am going to heat up the car REAL good before I bring it. I'm going to put new sparkplugs in the day before inspection, going to clean out throttle body maybe would that help?
Someone today told me that I can probably take the air bypass screw completely out of the AFM and that will help my emissions a great deal? Anyone know?
Thanks.
Thanks.
#35
If you're high on all counts, then it's usually your cat. As noted above, if you pull an injector wire, you should pass (I've never tried this, myself). Your oil would have no impact.
#38
I'd lvoe to.. but heres the deal. this would be a retest.. they already heard my car run, they know it doesnt run on 3 cylinders.. do they have the right to open the hood and fail it cuz an injector is unplugged
#39
I think its better to buy a $150 cat installed than to half *** the thing pulling injector wire, removing idle screw, or air bypass screw. Your car will run improperly and maybe even cause damage to your motor.
#40
High HC and NOx is a sure sign the cat is bad. There's no way to make any kind of adjustments with fuel or air or air-fuel mixtures that will lower both of them. They are inverse functions of each other, that is, if you lower HC, you'll get hgher NOx. Conversely, if you tune for lower NOx, you'll get higher HC.
#41
Okay guys. last question. Should I buy a piece of property in Connecticut so I can have no emissions testing?
(kidding)
I will try to find a generic cat at my local parts store that will work.... Anyone know what the pipe diameter is on both sides of teh cat?
(kidding)
#42
TRB0 GUY
Because of the free retest, try one thing that can lower both some (mostly NOX though). Like I said in the chat room, yank the cover plug and richen with the mixture screw until it runs funny, then turn it back a little. If it doesn't work, you're required to get a cat. Sorry Devon.
#43
Well, I just went and bought a universal catalytic converter for 60.00 at my local car parts store. It's some Clean Air brand or something. I'll have my dad weld this sucker in there, and i should pass right? Might need some extra 2.5 inch pipe though because this one is about half the length of stock one. Why is the stock one so damn big?
Edit - Oh yeah, which way on the mixture school is rich? Clockwise, counterclockwise?
#44
Uh oh.. just thinking.. is this going to fit in where the Cat goes ? I forgot that it's not the round type.. here's a picture of what it kind of looks like. Picture is one witha 3 inch in/out, mines 2.5
