OPRV - Late Valve, Late Block early hsg?
Originally Posted by rockfan4
Well, let's say it's a cold morning and you're running dino oil. The valve would open all the way, and the maximum amount of oil would flow through the valve. The oil would have to flow out the 4 holes on the side, and flow up the outside of the valve to the housing. Everything is normal, until it gets to the housing, which has a slightly smaller inside diameter. There's still the cutout that is the same size, just the other 3/4 or so of the circle. I wouldn't think it would be a problem, expecially living in Arizona and running synthetic. One test might be to see how the alignment tool fits. If it fits alright I'd give it a try. Or I guess I should ask first, is this for the spec car or one of the others?
Hmm I guess I probaby could attempt to machine out the housing a bit to ensure clearance.
I have a late housing off of a 87 S block. If intersted, drop me a line. I also have a early housing off of a 83 block.
toddandcharity@peoplepc.com
Thanks for input.
Sam,
Thanks for the housing. When I got from you I knew what is was getting and would have worked just right. Now with the late block it is little more complicated.
I am thinking I will just use my dremel and grind a little more clearance just to make myself feel good.
