Just got car back from clutch, now only blows hot air
I just picked up the car after having the clutch replaced. On the way home I noticed the fan ifor the cabin will only blow hot air. Really hot air. The AC doesn't seem to make a difference. I am wondering what the hell is going on.
Any info would be greatly appreciated.
Eric
Eric
heater control valve may have gotten screwed up, it is at the rear of the engine in the middle, try moving it from side to side to see if this helps to solve the problem, or i could be totally wrong because it is a late car, but this is the only thing they should have gotten close to when doing the clutch job, did you have them relocate this by any chance?
Just talked to the mechainic-he said it was probably the heater control valve, and if i could take a look for any loose vacuum lines. If I dont see any, not to take stuff apart and to bring the car in anytime for him to mess fix it.
Total cost was 1712. I ordered the clutch kit from zimms , that was $641. 9 hours @65/hr, and the car needed around 400 for parts like a clutch fork and some other stuff in there.
It is the heater controll valve vacuum line. One part is in the heater valve, the other end is just hanging there. Anyone have a pic of where the other end goes? I am gonna go look around some more in there.
Aha!!!! The list prevails. With a minimal ammount of skill, a vacuum hose diagram, and some longass pliers, the vacuum line is back in place.
Thanks a ton everyone.
Originally Posted by Macfreak007
Awesome, glad that it was such an easy fix, now go out and drive it, enjoy it! ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
