944S2 hesitation in short gears?
Here's a mysterious situation which I can't figure out.
The car runs great in long gears on the highway, but on short gear changes it has the occasional "hiccup" or hesitation.
The fuel filter was replaced last year, as well as the spark plugs. The ignition control module is about 4 years old, and the alternator was just fitted with a new Bosch voltage regulator. The DME relay has also been changed out, but the hesitation remains. Also, last time I checked, the TPS "clicks" when I move the throttle lever.
I'm looking for possible causes and can't pin any down although the symptoms suggest an electrical problem.
Your suggestions are much appreciated!
I did the generic 3 wire...
...from Paragon with the 'official' Bosche wiring kit. Was very simple to splice in to the existing wiring. Check their site for the Bosche part numbers for your S2...
-Steve
-Steve
Well, we replaced the O2 sensor on the S2 and the problem is still recurring.
I'm suspecting the ignition control module or the coil.
Any other ideas would be appreciated.
