Sound from the rear
You will have to pull the rotors to get to the parking brake shoes, they are inside there. Thread a bolt into one of the holes to help push the rotor/hub off.
Originally Posted by pearldrum944
I did the bearings recently, but this time the noises sound nothing like the bearings did. I don't get a constant grinding type noise.
And the culprit was...the parking brake. I finally decided to pull the hub off, someone that rode with me said the sound was coming from the driver's side. So I pulled the hub and the spring that holds the parking brake shoes horizontaly had come off. In several places it was worn down to almost nothing from rubbing on the hub. So pulled a spring from the parts car, put it back together and no sound. Thanks guys!
