Oil Cooler seals
After the new brakes and doing the CV joints I went autocrossing. Comming home my AC didn't blow cold anymore and started T/S at home. I found that the expansion tank had alot of oil in it. Time for new oil cooler seals. And, what is the best wway to flush out all the gunk from the system?
Lifetime Member
Lifetime Member
"Shout" laundry detergent or a citrus based liquid cleaner, about a cup added to a water fill after draining the coolant mix. Might have to do it more than once. Make sure you flush the system thoroughly with plain water after using the detergent.
Matt
Matt
