Help Please!!! Car almost together
Its been about month and a half and i am almost done except i am confused on some of the wiring.
Can someone show me a pic or explain to me the routing and how to hook up the wires for the starter and alternator and battery. Thanks alot
Hopefully she will be running soon so i can go and dyno her.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Nerd Herder
Daniel, I have the .pdf manuals I could e-mail you- about 75 meg?
I shoud re do my website and share this stuff. unless I could get in copywright trouble, that is.
i have pet and those other programs but i didn't see anything about wiring from the alternator?? that is why i was asking on how they are routed. Like along the back then on the side of the turbo etccf.. not sure how it goes. Thanks
The alternator cable runs out of the grommet on top of the duct. THen it heads straight across to the block and up. Then take a 90-degree bend towards the back of the car parallel to the harness. It rests on the two arms of the head-shield that's next to the turbo. There's some plastic clips that hold the cable to the heat-shield. Mine cracked off, so I run a zip-tie through the two holes on the heat-shield arms and hold down both the alternator cable and the wiring harness. Then the cable goes between the block and the air-oil separator and heads down to the starter.
k i got that part. But what wires go where on the starter. I think there is three different places they can go. Does it matter where u hook them up. Does anyone have a pic of a starter hooked up. Thanks i advnace.
two heavy wires go to 30 terminal on the starter, the large lug that takes the 13mm nut, the small wire goes to the 50 terminal, the small lug that takes the 8mm nut. The terminal that is bottom right as you look at the back of the solenoid has the braided cable that goes to the starter.
Ok, going off the picture you posted, the short stud on the lower-right (5-o'clock) is the positive-output to the starter itself. It already has a cable on it if you look closely. Screw on a nut to hold it tight and that's it.
The upper longer stud at 12-noon holds two cables. One comes from the positive output on the starter. The other comes from the positive-terminal of the battery.
The smaller post on the lower-left (8-o'clock) is the smaller wire from the ignition-switch.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Going with the pack
is quite monotonous.
Best thread EVER!!!!! Thank yous![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
My 944 will run tonight... My 944 will run tonight...
That is... if all goes well!
It has been in the garage in pieces since LAST february :O
16 months... that right? I can't count.
Anyway, this was the only place I was confoosed
Anyway, this was the only place I was confoosed![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
