Timing Belt job - Torque Specs?
Does anyone know what the correct torque settings are for the Upper & Lower balance shaft sprocket bolts, the 3 spring tensioner mounting bolts and the balance bolt tensioner roller bolts? Hopefully I can get my water pump / timing belt job wrapped up tomorrow.
Ok, I just found the tensioner lock nuts = 33 ft.-lbs..... still looking for the balance shaft sprocket bolts and the spring tensioner mounting bolts.
