Rear sag
Rear sag
My 951 is sagging in the rear, needs to go up i'd say 1.5". I ad a friend of mine take a look at it who is a porsche mechanic and he said the eccentric bolt adjustment was maxed out. He suggested doing torsion bars, but if there is anyway to get around doin that it would be good. Would say a pair of KLA rear coil overs get the rear up to where it needs to be, or am I in for t-bar replacement/reindexing?
Mike
Mike
Why not just lower the front to match
Coil-overs with a relatively light spring (80-125) might do the trick, but then you should really up the front just a tad. e.g for 80# rear spring go to 200# front spring, for 125# go to 250# front spring.
