Windshield reservoir leaking
Noticed colored water in the garage. Lucky it turned out to be the plastic Windshield washer reservoir had deteriorated and was leaking. Can I pour some kind of sealant into it or where is the best place to order a replacement?
1987 924-S Martinsburg, WV
Thanks in advance
Thanks in advance
Nerd Herder
You can pull the entire resevoir out to see where it's leaking from. (3 bolts IIRC) If it's a small hole a little epoxy will fix it forever, a larger hole can be fiberglassed in.
If the feed nipple is bad you are probably looking at replacing it with a used part (30 bucks or so) or a new white one- I dont have a source on the new ones. They arent in any catalog I have. If I can find it i'll edit this post.
