turn signals
turn signals
suddenly I noticed that none of my turn signals are working. A quick examination shows there are 4 fuses and a relay to check. The fuses check good. Not sure about the relay. I'll have to check the schematic to see what to jump for a test. Any suggestions before I start tracing?
I replaced the flasher relay on mine last year for a cheap ($10) one from Autozone. It fixed the problem (which was similar to yours but more intermittant), but it flashed the left and right one at different speeds. Oddly enough, I put the old relay back in and it's been working fine ever since.
So the first thing I might recommend is to take the flasher relay out, tap it a couple times, clean the contacts and put it back. Good luck!
Yea... Make sure you have the correct "european bulbs" If they are okay check if the 4 way hazards are inop too. if they are change the flasher relay. If the 4 ways work check into your signal switch.
Do a search on the forums, Someone should have the P/N number posted. I just changed mine a couple months ago.
Ok, I'm bad. The next time you take the dash apart, remember to attach the wires back on the Hazard switch. If you don't then your turn signals will NOT work. It wasn't the car, it was the owner.
