Whats up with the horn wire ??
1 Post
Wire for horn ?? is it that wire hanging under the engine ????
I saw something in the past that stated that.
I have had some kind of wire hanging under the engine, that is now separated from pressure wash.
Now , my horn don't work..
Is there a better way to route that wire etc....
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
That would most likely be it. But, the wire is like a harness that breaks off into 4 separate wires (2 for the low tone horn, 2 for the high tone) Is this only 1 wire you are seeing? If 1 wire is hanging one of the tones on your horn is disconnected. But, if thats the case 1 would still function (but sound really ****ty) It must be some other wire. Where exactly is the wire?
Andy
Andy
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
1 Post
Oh, thats not it then
I just went and stuck my head under, now that I can see stuff ( 2 cans engine cleaner and pressure washer ). I used to have a thick coating of oil/dirt over everything..
Anyway, here's pics
Anyway, here's pics
IIRC, that ground wire will cause the horns to stop working if disconnected.
Check this thread: https://rennlist.com/forums/924-931-944-951-968-forum/99398-help-early-944-erratic-horn-operation.html
Fuse 24 Assassin
Fuse 24 Assassin
led, you said it, thats the ground wire alright. You did connect it right? Do you really how many people you can't honk at after they keep cutting you off and brake-checking you during rush hour!? ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Andy
Andy
1 Post
Well it's kind of chewed up. I'd like to replace the wire.
Where does it attach to up top ??.
I'll just run some heavy wire and attach at that crossmember place.
