Rough Running Part II
I have checked most everything out. I am pretty sure all the vacum lines are ok. Most hold and pull a vaccum. Fuel and spark are being delievered. All four cylinders are running. I did a test of the MAF, and the TPS today. I just unplugged them while the car was running. When I unplugged the MAF the car would not idle good and kept wanting to die. So I figured that sensor is working. Then I unplugged the TPS and it seemed to help the idle a little bit. It didn't idle as rough. I was wondering does that mean it is bad or should I start looking for something else.
Hitsquad Ninja
When I pulled my engine out the other day, the passenger side motor mount was REALLY bad. It had a really big hole in the bottom and the stud was moving around with a lot of free play.
UAE Rennlist Ambassador
There are three things i would suggest that you check:
1) Check/replace the fuel injector sensor, located on the cylinder head nect to the water temperature sensor. It has a blue top and you cannot miss it.
2) Check/replace your O2 sensor, over the years, its goes bad.
3) Check/clean/replace the idle stabiliser, it CAN be removed (with some patience and persuation) w/o removing the intake manifold.
Here is a link that should give you hints/clues on rough idle:
http://www.clarks-garage.com/shop-manual/eng-15.htm
