What is this? Low Pressure A/C charge nipple?
I'm looking for the low pressure A/C nipple to top off my A/C system. I've searched the forums, but can't find an answer to exactly where this is. I found the high pressure nipple which i believe is on the small line by the drivers side shock tower. Can anyone please tell me if the item i'm pointing at in the pic is the low side in which i should charge the ac system? The tube snakes up from below and has a light blue plastic cap on it with a metal clamp holding it on. thanks alot 87 951
No, that's a test port. The low side port is on the compressor on an 87. Follow the larger of the two lines on the strut tower to the compressor. the larger of the two lines is the low side. Is will also be marked with an "S" for suction and the high side will be marked "D" for discharge.
can you tell me exactly where the compressor is? i've tried to follow the larger line with no success. do you have to get under the car to charge it? thanks.
'thanks for the pics guys. i guess it would have been too easy to have the low side input somewhere accessable from the top of the car."
On the '86 951, the nipple is on the hose up by the strut-tower... They took out a lot of good tidbits in going to the '87...
They switched the locations. The earlier cars had the low pressure by the shock tower, but in later years they reversed the low and high pressure ones so that the high pressure is on the shock tower and the low pressure is right with the compressor.
Makes it a real pain in the *** to get under there to the nozzle, but fortunately its something you shouldn't have to do more than once every few years.
MY '86 951 has both hi and low fittings on the driver side shock tower. My '87 NA has the hi side at the shock tower and the low side at the rear of the compressor.
On early cars (I used to have an '84) the low side fitting is at the front of the compressor and the high side fitting was in front of the reciever/dryer.
BTW: Where in NC are you?
For Carl Nall: I thought I was a clean freak, but I have NEVER seen an undercarriage as sharp as yours! Good job!
I just used A/C Pro to recharge my air after it had been retrofitted with R134. Hope this helps:
Using the diagram provided by Scootin159 above to locate the A/C compressor...
[IMG][/IMG]
Close up of Low Side Service Port - Note the cap is marked with an "L"
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
It literally takes 10 minutes to use this product and recharge your A/C system
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
