Smoke coming from distributor housing?
OK,.....I make a short trip today and started hearing squealing sounds. The next thing I notice is that I'm smelling burning rubber. When I pull into the parking lot, I pop the hood and notice that there's smoke coming from the top hole in my distributor cap. I immediately shut the engine off and had AAA tow it back to my house. It's now sitting safely in the garage.
I have a feeling that something is frozen and it's burning some belt up. Can it be a frozen water pump? The timing belts cam seals, rollers and water pump were all changed in May of 2000 @ 133,000 miles.
My car now has 157,00 miles on it. Any help? I'm afraid to start it up for fear of breaking the timing belt.
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
I'd say definitely don't start the car until you find out what's wrong. Maybe take the top cam cover off, take a look and snap a few pics? That can be easily w/o even lifting the car -- takes on a 10mm socket.
The timing belts cam seals, rollers and water pump were all changed in May of 2000 @ 133,000 miles. My car now has 157,00 miles on it.
That puts it at about 4 years ago and about 24,000 miles. However, the car has not been driven much in the past 3 years. I've only put about 3,000 miles on it since getting it last October.
Smart move having it towed home, there are a few guys on this forum who wish they'd done the same!
I change my belts every three years to be safe, but it sounds like you have a roller problem.
Did you see your new rollers with your own eyeballs, or are you taking someone's word for it?
Always the cynic...
edit, oh, I see you bought it recently. Did you see the bill for the work? Even then...
Trust no one but yourself.
Always the cynic...
Always the cynic...
Always the cynic...
Parts Used on May 2000 repairs:
Aux Shaft belt
fanswitch
water pump
timing belt
2 cam seals
1 roller
belt guide kit
serpentine belt
When you take the belt cover off look for this:
![](https://forums.pelicanparts.com/uploads3/Disas21089728259.jpg)
And this:
![](https://forums.pelicanparts.com/uploads3/Disas31089728278.jpg)
Thread:http://forums.pelicanparts.com/showt...hreadid=172187
And this:
Originally posted by peterjcb
The PO gave me the receipts for the past five years that he had owned it.
Aux Shaft belt
fanswitch
water pump
timing belt
2 cam seals
1 roller
belt guide kit
serpentine belt
Aux Shaft belt
fanswitch
water pump
timing belt
2 cam seals
1 roller
belt guide kit
serpentine belt
Take the front cover off and inspect for damage and check to see if the timing marks are lined up properly. If so, replace everything and count yourself lucky.
The fact that the belt was squeeling points towards the waterpump or an idler being siezed, if a toothed roller had stopped turning you'd get a different sound. 4 years is the limit on belts regardless of mileage.
OK, there are obviously shavings in the cover. The belts do not appear to be in bad shape to my untrained eye. However, I do see some rubber sticking to the top smooth roller but I don't notice any on the bottom smooth roller. The top smooth roller spins but it does not spin as effortlessly as the bottom roller.
Also the belt with the teeth on top and bottom (front belt) , appears to have a lot more slack that the inner single sided belt.
I have been leaking some coolant and I thought that it wasn't a big problem at the time. I did have to add a quart or so of coolant in the reservoir last night but I haven't started it up since. The water pump was replaced 4 years / 24,000 miles ago along with the belts and roller. I'm also wondering if my idler roller can be a problem because I see a rubber coating on it. However, it does turn.
I'm also wondering about the big idler roller next to the water pump... if that's what it's called. The rubber crumbs could be coming off that if it's seized.
