Need to locate cheap radiator....help?
Old 07-20-2004, 02:29 PM
Cyrus951
Cyrus951's Avatar
Lance,
I emailed Wayne, and got no reply. Is he vacationing or something?
Raven,
Have you/Are you planning to pick up Matt's radiator?
Doug,
I guess you're my only other option for now, how much would shipping be to area code 91773?
Old 07-20-2004, 08:54 PM
dmsog
dmsog's Avatar
Originally posted by Cyrus951
I guess you're my only other option for now, how much would shipping be to area code 91773? [/B]
Cyrus;
PM me your street address and I'll get a quote forthwith.
Doug
(UPS doesn't quote w/o the particulars)
Old 07-21-2004, 03:31 AM
Campeck
Campeck Rulez
Campeck's Avatar
dont mind me
Old 07-21-2004, 03:50 AM
bloodraven
bloodraven's Avatar
Campeck, don't spam in my threads...go find yourself a midget..
I have contaced Matt about his, but if he doesn't have it, then I don't know what to do....
Old 08-08-2004, 05:37 AM
Dilberto
Dilberto's Avatar
I put a turbo radiator in the 86' 944 NA, and the needle never climbs beyond the halfway mark. But this is also including the thermostat change, and oil pump rebuild. The turbo to NA radiator swap will require extra attention, because of the turbo's slightly taller vertical dimensions. The increase in coolant volume is needed to allocate a certain amount of coolant, for the turbo cooling system. A 1.5" small mount modification will need to be made, at the lower portion of the removeable tray...thanx!
Zach
Quick Reply: Need to locate cheap radiator....help?
