HELP Parking lights and dash lights no work!
I'm not sure if you're still connected to this account, but I'm having the exact same issue that you were. (on my 1983 Porsche 944)
After reading through your diagnosis and solution, I'm not sure which connector you ended up running a new ground to.
Any chance you remember this repair from 19 years ago? Did you run a new ground to the turn signal connector in the steering wheel stalk? Or another.
Thanks.
Thanks.
Good Luck
