Will this stuff work on my 84
86 951 springs
Set of caster blocks that came off of some used a-arms
Set of rebuilt strut mounts
Not sure if it is an upgrade or point less, will not work, etc.
Anyone want to let me know?
Thank you
Thank you
86 951 spring will increase ride height slightly - great for Paris-Dakar or other such offroadisms.
Caster block is likely from cast aluminum arm car and will not work on your steel arm car. Other, there is only one caster block type for the steel arm car and this would not be an upgrade. The caster mount bushing on your steel arm can be upgraded to Weltmeister sport type (red).
Rebuilt strut mounts will work, but for your car they are quite easy and inexpensive to replace the rubber and bushing.
Good Luck!
Good Luck!
