Caster block mounting holes stripped-best repair procedure
Old 05-25-2018, 12:01 AM
  #31
951and944S
951and944S's Avatar
Originally Posted by pharmacy
Mike S, Do you have the pics you mention in this post? I'm about to do the same thing. My idea is to use a plasma cutter to remove the "rectangle" outside the caster block area and remove OE "nuts" and weld in grade 8 M10x1.5 nuts then wire-feed the piece back in.
That's what I did once during a wreck repair.
Just weld a piece of like thickness sheet over you access hole when done.
Sketch out the nut on the outside before placing it and drill two 1/8" holes inside your nut trace to spot weld the nut.
T
Quick Reply: Caster block mounting holes stripped-best repair procedure
