Parting out questions (update)
Well the cars home, but I'll only have 1 week to work on it and I'll be busy with work (OT) for a few weeks.
I'm thinking a motor drop party sometime in early August. I should be able to get just about everything else stripped off the car before that. If that damn job thing wouldn't keep getting in the way of my Porsche time.
Ken,
I think we met at one of the dyno days in Kirkland. I don't think your car was running at the time. Rich was there too. I would love your help!!
Rich,
Mmmmmmmmmmmmmm beeeeerrrrrrrrr gggooooooddddd!
Right on!
Cyrus,
Do you mean the dash cluster or the sensors??
I love this place!
Ken,
Rich,
Right on!
Cyrus,
I love this place!
Jason,
I just need the gauge with the temp gauge and fuel gauge, not the entire cluster. Also, if you could lend me the sensor in the picture to see if that's what's causing the incorrect readings I'd appreciate it a lot.
I'm hoping my parts car shell will be ready for disposal pretty soon. I was thinking of leaving enough parts on it so a local Porsche junkyard would be interested in it, but maybe that's unrealistic. My problem is that the car is in my garage, so I thought I might leave the rear suspension on it so I can roll it out on some rear tires and a floor jack. Do these guys who pick up your shell use a flatbed with a crane or something? I could maybe get the thing out of the garage and then pull the rear spindles, etc.
Thanks,
-Joel.
Thanks,
-Joel.
Joel,
I'd like to know that too. One of the first things that will be coming off is the entire suspension. It will be on blocks in my garage as well. I'm thinking that I will just have to completly strip everything off the tub. Then maybe find a couple of high weight dollies to roll it out to the scrappers truck. Or maybe attach a wood frame/skid to the bottom of the tub and drag it out. Should be fun either way.
Anyone know what to do here?
Originally posted by Cyrus951
Jason,
Jason,
I'm not sure I could get it to you in a timely manner, I wasnt planning on gettinginto the interior for a while. Where is the thread talking about your problem, maybe I could help as I've had a few bugs in the same sensor in my car. PM me,
Jason
Originally posted by Skip
Name the date - Yakima is a good trip if I have the time - I'll bring the bird
Thanks Skip!!!
When you strip these cars down to the shell, they are really pretty light. A couple of guys could probably just drag it out of your garage, draging it on the underbelly. If you don't want to scrape up your garage floor, I suppose you could put a scrap peice of plywood down for the underbelly to sit/drag on. I was by myself, and just threw a chain around the back of it and drug it out so tilt/flatbed truck from the recyler could back up to it, and winch it up on his truck. Very little scraping on my floor from it. No rolling suspension required. You might want to check with your local recycler, and see if he works it the same way before you do this. And they don't want to see or take, anything but metal when they come to get it. Clean as possible metal scrap.
This is what the first shell I did looked like coming out of garage. The next time I have recyler over to pick up another shell, I'll snap a pic of how/what he uses. Oh, and I did remove all the garbage from inside before pickup.
Thanks,
-Joel.
Thanks,
-Joel.
More pics?
The first engine I pulled, had to use my small floor jack, blocked that up, moved car up in stages. Block points used are ones in back of front wheel wells, and forward of rear wells. Must position blocks carefully to keep from damaging rocker panels while jacking car up and down!
I dropped engine down on rolling platform, makes engine removal easier. Front of engine was already taken apart on this one, but can still be removed from car with it intact. You might want to use the flywheel lock, and break loose the crank pulley before removing engine, if your planning on any engine teardown. Just makes it a little easier to deal with later.
My first parts car ready to be stripped/engine removed. After this, I bought a long frame jack, so I didn't have to block up my floor jack. Looks scary, but it is very stable. I stripped alot of this car in this position, before I lowered it down further.
I've rambled on enough!
I had fun........YOU WILL TOO..........THANKS!
Ken,
Thanks for the pictures that just what I wanted to see. Today is my garage cleaning day/ building shelf space for all the parts. I'm putting together a 3-tiered system thats 12' long and to the ceiling. Should be enough space (I hope). The fun will begin soon!!
Jason
Jason
UPDATE:
Well I've got the garage all cleaned out, shelving built, work table built, and bugbombed. I will be going to get the car in a few minutes, and then off to homedepot for some blocks/2x8's. After thats all said and done I will take a $hit load off pictures and create a web page. I'm thinking instead off listing all the parts availble I will list the parts that are not (should be easier). I will also list who has dibs on what.
Should see a post tonight-ish.
Thanks for everyones help.
Jason
Jason
