OT - Car Registration.. how long till I have to?
Old 07-09-2004, 09:30 AM
Paul C 944
Paul C 944's Avatar
Devon,
I have a couple of bushings at work for the sway bar,let me know when you can pick them up.Just wanted to let you know I didnt forget!
Old 07-09-2004, 09:41 AM
Yabo
Yabo's Avatar
Yeap.. all the classics are (and I think all the range rovers in general. a small 8 banger at that, but it's an 8 nonetheless
Old 07-09-2004, 09:42 AM
Yabo
Yabo's Avatar
hey paul.. i'll let you know in a couple days if i need them. I might be just buying a 27mm bar with bushings and droplink.
Sorry for the trouble.
Thanks.
Old 07-09-2004, 11:24 AM
Paul C 944
Paul C 944's Avatar
I did the upgrade to the bigger bars,front and back.It makes a very nice improvement.I also did konis at the same time! So I really noticed the improvment in handling!
Old 07-09-2004, 11:30 AM
Yabo
Yabo's Avatar
Any idea if it's going to bew a problem if for now i keep stock rear sway with the 27mm up front?
Old 07-09-2004, 05:14 PM
adie
adie's Avatar
Thats pretty much the same engine I run under my bonnet, albeit a slightly tuned one. in the UK it's a standard replacement for pretty much anything as it's a cheap unit that lasts well. But apparantly the engine is real heavy being a V8 and all.
Old 07-09-2004, 09:54 PM
Paul C 944
Paul C 944's Avatar
Devon ,
if you keep the rear sway 14mm( kinda wimpy)or you may not have a rear,not all of them do.It will change the under/oversteer balance of the car.I would replace both to keep the balance of the car.Any suspension experts ,chime in.I believe that if you change the front only (bigger)you will increase the understeering on the car.
Old 07-09-2004, 10:13 PM
Yabo
Yabo's Avatar
well until I can afford/find a rear.. ( i think i have something back there...) i'll just put the 27 on the front and see hwo it is. I'm sure it will probably feel better.. and i'm not doing too much drifting in corners or anything right now anyway. especially this last week....
Old 07-09-2004, 10:21 PM
Yabo
Yabo's Avatar
what size rear sway bar matches up with the 27mm front? In other words, what say bar should I get for the rear?
Old 07-10-2004, 10:21 AM
Dave
Dave's Avatar
Don't bother to install the front bar until you have a 16-18mm rear bar to go with it, the understeer will be much worse than it is with the stock set up.
Old 07-10-2004, 10:27 AM
Dave
Dave's Avatar
Originally posted by Mike Markota
Oh crap...My conquest title has been signed since July of 2001 but I didnt buy the car until last January and I still have not gotten the title in my name...
So how hard is it to change that 2001 to 2004?
NJ just want's your sales tax too, but having an unregistered vehicle on your property is illegal in most towns (usually uninforced unless the neighbors complain, keep it out of view and nobody will say anything). Owners associations aren't the issue since that only applies to condos in this area, we don't have them for regular houses.
Quick Reply: OT - Car Registration.. how long till I have to?
