High pitched hissing sound in engine bay when accelerating, vaccum leak?
Hi! I just joined today because I’ve been trying to find out what this noise could be. I’ve owned this car for 5 months now? I’ve looked around the diffrent posts but cannot find anything similar to my issue. It seems to appear after accelerating and stumbles with the idle. I’ve looked around the engine bay but cannot find anything that could lead to it. There’s a bit needed with this car so I may be here a few times.
Its probably a vacuum leak making the hissing (actually sucking) sound. Also likely why you have a bad idle. Check all your lines, especially the small ones running to the FPR/Damper/Throttle body/EVAP system.
I have checked the small lines but have not seen any issues. I have not felt a vaccum between the throttle body and the small lines that run to the fpr though. I disconnected those lines and the sound was the same and the engine continued to run, is there supposed to be a continuous vaccum between there? And where does it get its vacuum.
