Plastigauge necesary?
With new rod and main bearings?
My only concern is putting an extra torquing on the crankcase studs...
Crank was measured to be in spec by the machine shop, so I dont see why plastigauge would be necesary with fresh bearings?
TIA,
Adrial
TIA,
Adrial
TIA,
Adrial
TIA,
Adrial
DO IT.
Administrator - "Tyson"
Since I've never done this before, I have a question.
So yo use Plastigage, what do you do if you find one or two bearings are out of spec? How do you adjust for this?
Actually, all you do is use a special machine (of course) that is made just for grinding rods and caps. There is a gauge on the machine that you use to check when you have grinded enough metal off, then you use the honer in the machine to make the hole round again. As for the crank-to-block caps, I imagine you can use the machine for those caps as well, though I have only done the rods personally. Probably an engine hone has the tool for honing that part of it. We had a pretty kick *** shop at my tech college I went to during high school.
Nerd Herder
I've used it- My take is I would rather trust my own measurement than take someone else's word that it's right. Cheap insurance as long as it's apart.
I've only fully rebuilt V8's tho.
Originally posted by Jfrahm
Resize the rods, regrind the crank, get undersize bearings, whatever it takes.
-Joel
-Joel
Originally posted by 944T4ME
As for the crank-to-block caps, I imagine you can use the machine for those caps as well...
