Long RennBay Fuel lines on 951
Anyone with a 951 running the RennBay Fuel lines, the longer version? I ordered this set cause I thought the extra length was needed to route the fuel lines to the back of the firewall, However I went to mock them up and the supply line seems to be way to long. To make it work it seems I would either need to cut the hose and have the fitting reattached or make my connections very low in the fender well almost underneath the car. Anyone have pictures of how they routed theirs?
I see nothing on Rennbay website about longer version fuel lines (only the "LATE KIT" for 951, which appears to be sold out/not available on the website)
https://rennbay.com/Fuel-System/944-...1983-1989.html
Do you happen to have a link to the page/product you purchased? Was the wrong product perhaps sent?
I assume you have already seen this video?
Lastly, you may want to contact Rennbay directly
Rennbay only lists the OEM-length set on their website, but they can accommodate other lengths. When I purchased my longer set from them a couple years ago, I just called Travis and explained that I wanted to route the lines back to the firewall. He told me to submit an order and overpay by an extra $20 and he would cut them to the necessary length prior to shipping. Fitment was on point and I did not end up with extra material. Maybe give them a call?
