My early 944 issues
So had my 84 944 for about a year now. Same issue is happening just at different rpm’s.
Replaced plugs and wires, and coil.
New fuel pump, filter, and strainer.
new dme, and afm from 87 ( since changing it the shifts are way smoother but now the break up happens a bit earlier in the rpm range and feels like it lost power
is there any chance this could be some issue with timing my idle is super low and almost feels
like stalling
like stalling
What do the plugs look like? Low idle can be over-fueling, commonly caused by leaking FPR, Damper or injectors. Those issues are getting more common due to age and fuel additives.
A simple fuel pressure test will tell you whether the FPR/damper is bad. Maybe try that first.
Also this:
https://www.clarks-garage.com/shop-manual/ts-01.htm
Also this:
Try pulling the vacuum line that goes to the FPR. If it’s bad, there’s a good chance that fuel will come from the vacuum line, indicating a hole in the vacuum chamber diaphragm. This can be done on both the FPR and the damper. No fuel= good. HTH some😀
yes so I did do this test a few weeks ago before changing the afm & dme to late model units. When doing the test there was a slight change in idle but no fuel in line.
Tiger03447 (07-26-2024)
