Permanent Heat
Permanent Heat
My A/C recently started blowing hot at all temperature settings. But it's different than last time (which was a broken clip).
Now the vent to the left of the steering wheel blows hot, but if I close that vent, the hot air comes out the vent surrounding the trip odometer reset button. The center vents still blow cold air.
I checked the heater clip, and it's still attached. I played with all the A/C ***** and buttons and the heater clip and the arm attached to it (in the picture below) didn't move.
Anybody know what the issue is? Is there a way I can force the vent into the cooling position?
Thanks.
Thanks.
I've been trying to get this doped out as well...apparently there are two solenoids/vacuum switches near the passenger's left knee...those apparently control the flaps...Let us know what you find...
