Troubleshooters Needed
#32
I’ve been having an idling issue with my 85.5 944 and am desperately searching for a solution. The car had been starting strange and making sharp crank sounds before starting after a couple gos, and then surging between 1-3k RPM. Sometimes it’d start fine, sometimes it’d start fine and then develop the same surge while driving. In my latest attempt to fix it, I replaced the ICV and icv hoses, cleaned grounds, and replaced the manifold gaskets. Also did the heater control valve while in there. The PO had the vacuum lines replaced (Lindsey kit). The car after that still started bad at first then would start and die quickly, and then for a few good tries started great and idled perfect 1-1.2k RPM. Few minutes later wouldn’t start or faded.
I plan on replacing the throttle bottle seals and potentially looking into the TPS but need to do more research. If anyone can help me solve this I’d be forever greatful 🙇♂️.
best,
Mark Bogle
best,
Mark Bogle
I have a 88 951 production race car.
Lloyd
#33
Hello Lloyd, thank you for your response. I contacted the PO and if the crank position sensor is the same as speed and/or reference sensors, he already replaced them. I looked online and it looks like people use these terms interchangeably? Feel free to correct me. I believe there may be a sensor issue, but am first going to try and set my TPS as I did not do that when I installed my new unit
#34
