Rear shoulder belt stuck?
For some reason, the rear driver-side shoulder belt is stuck in the "locked" possition. It's fully retracted, against the rear seat, and I can't pull it out to lower the rear seatback.
Anyone know how to get the retractor to let go??
One of the shoulder belts would intermittently stick in the retracted mode. I would give sharp repeated jerks on the belt and most of the time retraction mech. would loosen its grip and the belt would unwind.
I finally got tired of this and disassembled the unit. Inside I found a cup with a small steel ball. The ball rests in a small indention in the bottom of the cup. There is a lever on top of the ball which is inturn attached to the retracting locking mech. What I found was several small pieces of dirt had entered the cup and were displacing the ball out of the small indention and lifting the lever and locking the retracting mech. I removed the dirt and the belt has worked fine ever since.
I hope that this helps
They take small hands to remove, but...
Pull cover carpet panel away from the side where seatbelt retracts into. Remove the bolt holding it into the little metal box shape (17mm I think).
Note that these will only allow belt to feed out within a VERY NARROW angle. The angle provided by the mounted belt, its associated guide through the carpet cover, and the mounting point on the C-pillar is the perfect angle in a car on LEVEL ground. It's the devil to get it right on a "free" unit, just takes patience.
Inspect webbing for wear and fraying while you're at it.
Note to Devon: No go for the 85.5. Take a look at cars from about 88 on (maybe mid-87) and you will see the metal box under the carpet cover where the retractor resides in later cars. That's a must have item for the factory rear 3-point installation.
