JIC Magic Coilovers
JIC Magic Coilovers
I'm wondering if anyone has these or heard about them. I'm thinking of getting a set. A bit pricey. Just wondering what peoples feedback on them are.
Front Auto Cross Setup
Camber Adjustable Upper Mount
Helper Spring
Ride Height Adjustment Bracket 15 Way Damping Adjustable
Our flagship coilover setup. Features a light weight, 15 way adjustable monotube damper that ensures high strength and fade free performance. The ride height is adjustable separate from the spring perch giving you maximum suspension travel at any setting. This also allows for proper corner weighting of the vehicle without effecting spring preload settings.
Has all of the great features of the normal Cross Competition, but is custom tuned to the racer's needs on a case by case basis. Drag racers, road racers and even autocrossers will benefit from our custom tuned suspension. Price dependant on necessary configurations (i.e.. extra helper springs or very heavy spring rates.)
The cost is around 3k. Supposed to get rid of the Torsion bars. The owner of JIC-Magic used to own a 944 Turbo. JIC-Magic is known for doing japanese cars but they have a division called Cross that does european. They also used to sell a 1 piece titanium exhaust that weighed about 10 pounds.
Helper Spring
JIC are some of Japan's top coilovers, if you've got the money (and the need for them), you won't go wrong choosing them. I'd compare them with Moton/JRZ.
Sam
Sam
FYI - I've compiled a list of 944 suspension suppliers (including JIC) at the following page:
http://www.weissach.net/Suppliers_92...spensions.html
Karl.
Karl.
