Cam Tower Bolt Striped
I was changing the water pipe on my 83 and one of the bolts that holds the pipe striped, the one toward the front of the engine. This just after I replaced the cam tower gasket a month ago. It looks like the PO had already put a heli coil in it. Any suggestions? I was going to try and see if I could run a tap through and put in another heli coil. Think I could do that without pulling the cam tower? I guess the next would be to pull the tower and drill and tap for a 12mm cap screw. Has anyone had any luck running with one of the cam tower bolts missing? That has certainly crossed my mind.
