Could a bad heater control valve cause these symptoms?
1) On idle the temp increases, often up to the fans on high point or right to the second normal range mark. Fans dont cool it down.
2) On the highway cruising, same as above. Or in stop light to stop light. Day or night doesnt make a difference for 1 or 2.
3) Turn on the heat... Temp drops, pretty quick too. Turn heat off... Temp slowly begins to rise. How quick will depend on weather im on boost or not. I was able to repeat this easily 20 times in a row, exactly the same thing each time. When I turn the temp **** to max, there will be a very faint click behind the dash a second or two after, thats when the temps drop. Sounds like a relay clicking. It will work the same way weather in motion, or at idle. At 40MPH, 80, or even 100. Only difference is when idling the changes happen slower but they happen.
And lastly...
4) Could a bad heater control valve leak coolant when the car is parked????
And lastly...
1), 2), 3)
This sure looks like a radiator problem at first sight. could also be air trapped inside.
Might want to check the radiator outside first.
Built: 1986, today:2004, So there is a chance that there is about 18 years of crushed highway fly corpses and other undefined debris blocking the fins.
4) Not common (to my knowledge). Failed heater valves tend to open the flow to the core rather than leak.
TakeCare
TakeCare
Originally posted by Hans
1), 2), 3)
TakeCare
1), 2), 3)
TakeCare
