Help with removing the condenser?
Does anyone have any recommendations on the best way to remove the AC condenser? IO've got a 968 engine in the car with the stock 944S radiator, which tends to run very hot in summer heat.
The freon is long gone (AC hasn't blown cold in 4 years), so I don't think that the system is under pressure. Is this a straightforward "loosen the bolts" procedure, or are there any gotcha's... Anyone have any step-by-step instructions?
Also, what are people using for screen materials to protect the radiator from stones and other debris on the track. Anyone have any pics and/or advice as to what to use and how/where to fasten it on the front spoiler?
Thanks!
Matt
944S with 968 Engine (Running 944 Cup in the Super Cup class as a 968)
Thanks!
Matt
Matt,
I am about to do the same thing, remove the condenser and related plumbing. I found a little help on the Paragon site regarding the AC delete.
http://www.tech-session.com/kb/index...x_v2&id=37&c=4
It basically says to remove the front spoiler. I have not done that yet, but it looks fairly easy.
Sorry, do not have any info or using a screen to protect the rad.
Let us know how it goes, I will do the same if I get to it before you.
Shaun
PS. What year is the car?
Shaun
