so what do you do when you strip that cam sprocket bolt
Old 06-12-2004, 04:41 PM
Cass944
Cass944's Avatar
Default so what do you do when you strip that cam sprocket bolt
yeah...
what now
the 12 point bolt inside the cam sprocket is stripped.
Old 06-12-2004, 04:48 PM
Bones944
Bones944's Avatar
Same thing happened to me a couple of years ago. I used a pneumatic hand grinder, similar to a Dremel tool, and ground off the head of the bolt. It took an hour or so, but the shaft came out with my fingers when done. I ALWAYS replace the cam bolt when I remove it; they only cost $3.
HTH
Old 06-12-2004, 05:09 PM
ibkevin
Defending the Border
Rest In Peace
ibkevin's Avatar
Drill out the hole enough for the head to come off, remove the sprocket, throw a stud extractor on it, and--have a replacement ready to go!!
I used the original version hex head as my replacement.
Old 06-12-2004, 05:47 PM
Cass944
Cass944's Avatar
ok im all the way up to the biggest drill bit i have. and the head still has not come off. whats the biggest size i should need.
im at... uhh the number on the bit looks like... 21/64 or 5/16 is another bit that i was using they seem to be the same size though. but i mean dang how wide is the bolt.
Old 06-12-2004, 06:26 PM
Cass944
Cass944's Avatar
ok i got pretty far with a 3/8 bit but still no luck. do i need a bit that is actually bigger than the opening in the top of the bolt?
Old 06-12-2004, 06:54 PM
Cass944
Cass944's Avatar
ok i found a thread saing to use a 7/16 so i found that and now im like half way throuhg this bolt and i cant tell if im even geting any further... time for a break.
Old 06-12-2004, 06:55 PM
Sam Lin
Sam Lin's Avatar
You need to drill the head off, which means a bit nearly as large as the bolt head at least.
Sam
Old 06-12-2004, 07:00 PM
Cass944
Cass944's Avatar
thats what im doing. its just going sooooooo slow.
Old 06-12-2004, 08:08 PM
Cass944
Cass944's Avatar
i was just informed i a using a cement drill... that might be a problem
Old 06-12-2004, 10:06 PM
Chris Prack
Chris Prack's Avatar
Uh yeah.........concrete drill bit no good. Switch to a metal bit. While it is less challanging, it makes up for in speed.
The bolt is a 10mm bolt. You only need to go just over 3/8's and wiggle the drill. The head of the bolt will come off and you can then remove the rotor drive. Once that is off the remaining bolt will turn out by hand.
Old 06-12-2004, 11:26 PM
Granite 944
Granite 944's Avatar
I've drilled many a bolt head off destroyed fasteners. The only "trick" is to drill up to and no more than the diameter of the bolt itself, not the head size (slightly under the diameter of the bolt is preferable), but you must be drilling dead center of the fastener to achieve the proper result. Make sure your not drilling into the bolt head any deeper than the head. The center of a regular twist drill can go deeper than the head, but not the full diameter of the drill, or, if your off center, you couldl be drilling into parts you really don't want to destroy. If you do just this in this manner, and head hasn't "fallen" off, you can sometimes smack it from the side, and get it to finish breaking off. 3/8” Drill bit is the largest I would recommend stepping up to. Drill as straight as you possibly can. Use a 90 degree motor or 90 degree motor adapter if you are drilling it while still on the car. A regular twist drill bit is the way to go.
Pic of 1st (hopefully last) cambolt I had to drill out. I drilled a bit to deep, but was pretty well centered
Good Luck!!
Old 06-13-2004, 01:04 AM
Lead Foot 944
Lead Foot 944's Avatar
I dont even know what to say......Did you use a 12 point driver in the first place....? Or use something else..like a torx.....Got called into work today......still going to the car show though...tomor.....
DAmian
Old 06-13-2004, 02:09 AM
944T4ME
944T4ME's Avatar
I have a set of extractors if you need to use some once you get that head off. Also, you can take a chisel and cut a groove, the deeper the better. Then just use a flathead and unscrew it. Once the head is off, it will take very little pressure to unscrew it. I have 12pt drivers if you need, too.
Old 06-13-2004, 02:13 AM
Cass944
Cass944's Avatar
i have lots of 12 point drivers. no luck with that though too i took every precaution possible to make sure the ratched stayer straight aligned with the bolt too. it just wasnt gonna go. it doesnt really matter anyway its just a cam i got for free to use while mine gets powdered.
Old 06-13-2004, 03:25 AM
Cass944
Cass944's Avatar
ok started at like 10 this morning. and now its about 1:12 am and its still not all the way through. im suprised the drill has lasted this long. havent broke any bits yet though.
Quick Reply: so what do you do when you strip that cam sprocket bolt
