Cam chain tensioner pad luck plus a question on fuel lines
Originally posted by superman90
Can you just replace the pad without removing the cam chain? and if so is there a write-up on it?
Thanks,
Evan
Thanks,
Evan
Taking the fuel lines off makes for a lot less wrestling, that's for sure. I did the pad at the same time as the lines, so that was a no-brainer.
Thanks,
Evan
Thanks,
Evan
In any case I used the following link for instruction:
http://boerger.golden-tech.com/image...eplacement.htm
Big E - just out of curiosity, how did you take off those fuel lines??? They seemed very brittle and easy to break so I didn't want to try and push them at all.
Hmm, well, one of them attaches to the damper (or maybe regulator, I don't remember) via a hose clamp, so just loosen the clamp and jimmy the line off with a screwdriver or such. The other attaches via a compression fitting, so there's two nuts, 17mm and 19mm I think. Hold the one closer to the fuel line and loosen the other one, and you're done. Once you break the initial connection, you can loosen it with your fingers. The metal fittings shouldn't really be all that brittle (not that I'd recommend taking a 3 foot crowbar to it either!). The rubber probably is brittle, so use the opportunity to replace them before they start leaking fuel on the exhaust manifold (= fire).
If you remove the 16V cam cover for any reason, it's also a good idea to replace the cam cover gasket if original on the car because it will leak otherwise.
When I did mine, I replaced the gasket, spark plug hole O-rings and bolt gaskets.
One thing I had a terrible hard time doing was getting to that upper-left valve cover bolt, because the fuel hoses are right in the way! I couldn't move the lines out of the way enough...making for a maddening experience.
Is there an easy way to get to that upper left bolt, maybe with a longer allen wrench, etc??
Also...do the spark plug O gaskets go round-side towards block, or flat side??
You should be able to get the cover gasket, the spark plug hole gaskets, and the 13 or so small grommets for the bolt holes for about $30-$40. Zims has them as a set for $35 I think, I got mine from the dealer for about $30.
Some also suggest replacing all the bolts holding the cover on, as the bolts can stretch, but at $9 EACH (!) that adds $130. Mine seemed fine, none broke, so I reused them.
