Option code sticker.
Old 06-10-2004, 01:49 AM
Eyal 951
Eyal 951's Avatar
Default Option code sticker.
Where is it? I went looking and found this, but it looks wrong, and most of those numbers dont come up with otions, or really off ones like 944S Cab. and luxenberg edition. I dont think I have a luxemberg edition 944S cab
~Eyal
Old 06-10-2004, 01:51 AM
Eyal 951
Eyal 951's Avatar
forgot the photo...
Old 06-10-2004, 01:58 AM
mybaby924s
mybaby924s's Avatar
Mines in the back. If you lift up the hatch carpet it should be there.
Old 06-10-2004, 02:00 AM
washington951
washington951's Avatar
down in the spare tire well - it will face the back of the tail lights.
Old 06-10-2004, 02:02 AM
Eyal 951
Eyal 951's Avatar
that is in the back, stuck to the bottom of the carpet.
thanks brian, I'll check!
~Eyal
P.S. so what is it i seem to have found? maybe a part number for the rear crapet and padding?
~Eyal
Old 06-10-2004, 02:04 AM
Porsche-O-Phile
Porsche-O-Phile's Avatar
A warning to check your turbo impeller vane hold-down nut.
Sorry, had to.
Old 06-10-2004, 02:08 AM
Eyal 951
Eyal 951's Avatar
Sorry, had to.
you like that a lot huh? you want the impeller as a souvenir after i rebuild that turbo? you can frame it. check YOUR turbo!
~Eyal
Old 06-10-2004, 02:45 AM
glen2002
glen2002's Avatar
eyal, no idea what you found but it starts with a 945 which is the part code for RHD 944. As everyone else said the option codes are near the spare wheel well
Old 06-10-2004, 04:04 AM
Porsche-O-Phile
You can bet that nut will be lock-tited in a serious way and torqued down pretty well! Heck, I'd tack-weld it on there if it wouldn't disrupt the balancing! Seeing what that nut did to your turbo / engine was enough to make me a believer!
Sorry man, we all learn from each others' pain. I'll bet you check your a/c high pressure hose & sway bar bushings now, huh? Hopefully only another couple of weeks and I'll get those bushings & hose replaced and back to where I was. . .
BTW are you going to just keep it as a spare or are you considering something crazy like a TT setup?
Old 06-10-2004, 05:19 AM
Hans
Hans's Avatar
PN 945 555 063 03/2FR
PET syas: color unknown....
Text says: Porsche verkleidung faltrad
Suggests cover for the foldable spare tire.
So: most probably carpet
TakeCare
Old 06-10-2004, 05:30 AM
swimmingly
swimmingly's Avatar
Hans was right, 945 555 063 03 is the part number for floor lining 85-91 (coupe)
Old 06-10-2004, 05:58 AM
hoffman912
The Hoffinator
hoffman912's Avatar
you found proof that your car is really a vw and audi hybrid, and not a real porsche
god that one was too easy.. sorry i couldnt help myself on that one buddy, no hard feelings
Old 06-10-2004, 08:20 AM
Hans
Hans's Avatar
The 356 was a sports car with as much standard (VW) parts as possible
The 911 was an update: the 356 was too small
The 912 was a mixture: 911 body / 356C engine
Roughly there are only 2 complete original porsche designs: the 928 and this
http://www.charlestown.org/ct-org/ct...rt_porsche.asp
To my surprise it has actually been exported to USA
Consequently you may consider a sports car with an high content of VW parts to be real Porsche!!!
There are things in life I cant resist, no pun intended
TakeCare
Old 06-10-2004, 11:41 AM
KLR
KLR's Avatar
The option code sticker is near the left side tail light, inside the cargo area, underneath the carpet. The first option you should see is C02 (indicates catalytic converter) and you will see your paint code at the top of the sticker (L041/700 for black).
Old 06-10-2004, 03:06 PM
Eyal 951
Eyal 951's Avatar
thanks guys, I'm goin out to check now. and harry, must i remind you what your driving?
~Eyal
Quick Reply: Option code sticker.
