55-60 mph shake
I'm working out the final bugs in my '87 951 and I have the shake in the steering wheel starting at about 55 mph and it goes away above about 65 mph. I know the solution is to drive faster
but the traffic in California doesn't always allow it.
Here's what I have done recently:
- new tie rods (both ends)
- newish steering rack
- steering linkage from column to rack seems tight
- new sway bar bushings
- wheel bearings are adjusted right and appear tight
- ball joints are just rebuilt
- new wheels and tires, just balanced
- new brake rotors
- control arm bushings look ok
- front struts seem ok
The only thing left is the upper strut mounts. Those things are expensive !!
Is this just something that these cars do or am I missing something ?
- new brake rotors
Originally posted by brad-cam
- wheel bearings are adjusted right and appear tight.
I'm working...
SNIP
SNIP
I'm working...
SNIP
SNIP
In case you have lock nuts, they differ in weight from normal wheel nuts. This weight difference will cause an un-balanced situation resulting also in the shudder as described.
TakeCare
