Engine Swap 2.7 into 2.5 - No Spark or Tach Bounce
Hi all
I have recently put a 1989 2.7 complete engine, engine loom, and ECU into a 1986 2.5 car but I now have no spark or tach bounce. The crank sensors are from the original 2.5 engine and are spaced correctly. Any ideas, please?
Thanks JW
Thanks JW
jhowell371 (11-21-2023)
Start at the beginning - engine troubleshooting
https://www.clarks-garage.com/shop-manual/ts-01.htm
Since youve apparently verified you lack spark you can start at the ignition system troubleshooting section:
https://www.clarks-garage.com/shop-manual/ign-04.htm
And just in case, here is the alarm bypassing procedure:
https://www.clarks-garage.com/shop-manual/elect-23.htm
