Momo "Porsche Crest" Horn Button Question...
I bought the porsche crested momo horn button awhile ago on ebay, went to install it the other day and noticed it only has one metal tab vs. the two metal tabs for the original momo horn button for the two wires. Im guessing this thing is broken, can anyone confirm?
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Sam, I don't think it is broken either, when I tried to buy one from MOMO here they said they don't make them anymore due to copyright issues, so I am guessing yours is aftermarket and slightly different from the original
Originally posted by JCNNJC
I have the same thing, so its not broken, I got mine to work, one wire on the button hook, the second down below where the round horn wire hits.
Good Luck
Good Luck
Originally posted by SamGrant951
So just tape off the ground wire or....?
IIRC, you should have a silvery metal plate that mounts under your wheel, between the wheel and the hub. The plate has a flange (points out toward driver) to which the horn button assembly can ground. In that instance, your horn button should just kind of snap in place and a bare bar/wire that isn't really visible in your pictures should contact the flange. If you have a copy of the Momo steering wheel instructions, the horn button you have is the same type as picture A, example 2a.
