Fog lights
On an '84 944 installation isn't too time consuming. A couple hours to maybe 4 hours depending on how fast you work. You would have it easier than the turbo guys where removing the air intake plumping and pulling out the alternator (to work on it as the turbo makes it near impossible to replace the voltage regulator with alt in place) takes most of the time.
Luis de Prat actually ended up getting a FullBoat headlight package which should be at his home in Barcelona by now. I think he is going to put it in his S2 cab so can report back on his install time.
Jeeper31, i put the full upgrade on my 924S a few weeks ago. I can give you a hand with it one day if you want. Took me about 4 hours working at a very slow pace. Im in Nassau County, Syosset to be exact (near Oysterbay).
