Correct odometer gear
I need the gear ⚙️ that goes here. Part number?
This is what i got from FCPEURO but unfortunately its not the right gear and it seems it doesn't fit on anything on my cluster
1986 porsche 944 N/A
thanks!
https://www.odometergears.com/
It walks you through exactly how to determine what gear you need based on tooth count on old gear (or the one next to it if the existing gear has disintegrated). You may also want to look at the products for other years/models of 944 to find the gear above (for some reason it looks like its a 15 tooth gear from the 968 or an M15 from a non-US cable driven gauge cluster). Very odd if yours is supposed to be a USDM 86 model
Also, please search before posting - this has been covered a million times. (google: "porsche 944 <question> forum" will yield a plethora of posts and threads)
There is no part number - the gauge cluster is a unit.
