Big Reds/calipers in general
Big Reds have been milled down 12mm, both mount pts, for prior custom application. Question is can this be used with spacers to return to stock caliper mounting height. Note: to be used on 86 951 with LR Adapter kit.
From: Formerly the DPRK, now seeking political asylum in Oregon
After second thought, I might not...
I can imagine using spacers in place of the solid material that was removed might introduce a bending force into the middle of the mounting stud (or bolt).
But I'm not a mechanical engineer. Are there any real mechanical engineers present?
Help identifying red caliper. It was previously Black. Pistons 36/44 Big Black??? Sanded caliper is from 89 944 turbo (928 S4) for comparison.
If Red caliper is in fact a big blk/big red I'll need the shiny metal clips x 4 that hold pads.
