How to remove a Philips screw?
1 Post
I'm rebuilding the AC compressor, and found a few Philips (a.k.a. plus) screws inside. They are tight, and even a hammer-driven impact wrench didn't work. Both the bit and the plus grove on the screw got partially damaged.
Any suggestions? I would prefer not to drill it through as it's inside the compressor, and would be hard to clean from debris.
Thanks, Stan
Thanks, Stan
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
I had the same problem with a couple of alternator screws this winter (tried oil and impact wrench) -- ended up getting a rebuilt one and called the old one a core....
I wish you luck!
That's my best guess.
If you are worried about metal shavings inside the compressor, then this will not work either though =(
Just keep hitting it with PB blaster, and check it to make sure it's not locked in there somehow, like that damn allen bolt on the PS pump, lol.
1 Post
Thanks, I'll try to slot it as suggested, and cover with grease (nice idea!).
I also though about drilling and using a screw extractor, but honestly, I tried it twice in the past, and broke the extrcator bit both times... And then it goes pretty much hopeless.
I know some people heat stubborn bolts with a torch, and then supposedly it goes easy. I never tried it myself. Do you think it would work here? Probably not the best solution - heat might ruin the compressor plate. I don't know..
Did you try a Phillips bit socket on a breaker bar? You can press down really hard on the socket to maintain good contact with the screw while you try to rotate it with the breaker bar.
