What is this on my 944S??
IIRC that is to speed up engine when you turn the steering wheel all the way. To help the power steering. You should have a plug somewhere under there with a rubber boot around it.
Eon S.
Eon S.
Does that thing next to it seem right
to connect. And I know the bushing needs to be replaced. Is that hard and where do I get the parts?
Newbie Idoktr
Newbie Idoktr
to get that stuff under there youre gonna need somethIng stronger than simple green if you want to get it clean easily. Try castrol super clean degreaser, or Gunk brand engine degreaser both work wonders under a car.
i think thats the wire that you are supposed to have unplugged from the power steering pump. there was a porsche recall to have all these unplugged, i believe they cause an engine fire due to possible shorting otherwise.
i may be wrong but these are words of caution.
Mine has been unplugged for 13k miles now. Something wrong with it because it causes the engine to quit when it is plugged in. I have not had time to look into it and I cannot find it on the 87 wiring diagram from the factory service manual.
Originally posted by azmi951
jonnybgood where did you get that wiring diagram?
