what is it?
what is the yellow plastic thing thats bolted to the water pump? it has a neck, but nothing attached to it on my car. im pretty sur ei took it off before and it was flat bare metal under it. i cant remember the other question i had.....i dont want to go to work tomorrow.
I have the same thing, I don't know what it's for either, it doesn't leak and doesn't seem to do any harm. It doesn't weigh much and I'm not sure it really serves a real purpose. It right above the power steering pump area correct? I want to know what it's for because I thought I was missing a hose when I first got the car.
Exactly. If you look at a new or rebuilt water pump, you either have a block-off plate or an opening there (behind that nipple) depending on whether you have a na or turbo car. On the turbos, there's a water line that hooks to that - goes (I think) to the intercooler. It doesn't hurt anything. If it REALLY bothers you I suppose you could remove it (check to make sure this won't make your H2O pump leak before you mess with it) or hook a "dummy" hose to it or something.
That block off plate is there so you can use an updated turbo water pump on an NA car.
On a turbo that fitting is part of the cooling system for the turbo, complete with thermostat.
