Anyone have a TPS?
Mine crapped out this morning on the way to work causing a high idle. It currently idles at 1.8k.
What's weird is that it seems that the return spring is not puling it all the way past the click.
Senario is: I start the car and it idles normally. If I rev it to anything less than 2k, it return to normal slowly. If I run it above 2k, it settles at 1.8k. While sitting in the parking lot, I popped the hood and barely touched the TPS and it returns to normal idle. It still clicks like normal just off idle. I almost want to think the spring is not pulling last that click point to idle.
Is this really the TPS?
Daniel
Daniel
Peter...Whaaaat's happening? Uhhh....yeah.....See......we have a new way of doing the TPS reports.....Did you get that memo??
haha...sorry...had to do it. Just watched Office Space this weekend. When I saw "TPS" I couldn't hold back. If you haven't seen this movie...I recommend you rent it ASAP! At least then you'd get my joke!
As far as your problem goes....can't really help you there....sorry....
