Coolant leak...
Coolant leak...
Alright, been having a fiasco with my cooling system, finally it started doing something obvious (ie leak).
It gets a good solid leak going on the passenger side of the engine bay, it seems to be in line with the oil drain plug and just near the tie rod area.
Im going to go jack it up and take a look. My first thought was the rad drain plug cracked while I was changing the coolant and its just dripping back along the skid pan thing and thats where it comes out, but its weird that it would drip in the same spot in 3 different driveways, all that are sloped differently etc.
Is there anything else cooling related in this area that could leak at a good rate, a fat drop every 2 seconds even. Ive aleady checked the bleed valve and that area is dry.
Large file sorry. Its dripping at a good rate off that bolt head. It seems to be dribbling around from the side there, and dripping off the bolt.
Is this a sign of water pump problems?
Originally posted by '88-924S
If the leak is in that area I would say your Wateer pump and or seal is bad. When is the last itme it was replaced?
Originally posted by bloodraven
i think its supposed to be replaced eery 60k....not sure though...sounds like it went bad, I think thats where its supposed to weep from
Let me tell you this--CHANGE THE PUMP! Do a search on bad waterpumps and you'll happily get it done. Why not do it yourself? I did it for the first time not too long ago and it wasn't that bad. I did by myself and at one point thought I was crazy and I'd never finish, but now I could I think do it in four or five hours.
Although I believe the factory says 45k for belts, the accepted number of miles by most here is 30k.
