Alok.. clear your inbox
Pm:
Did you have any problems with the little set screw on the rotor? Mine does not want to come off. I have already stripped the allen head on the screw. Any ideas how to take it off?
Thanks,
Alok
mine was a little hesitant to come off first but just be paitent and do not put to much strain on it and it will not strip...
if you already stripped it.. try taking the allen key and put some tape over it so as to fill the stripped groves and get a good fit.. and do not put to much strain on it or it will get worse..
if that still dosent work let me know
Thanks,
Alok
Cleared inbox.
I have tried that, but it is on too tight. I have used some WD-40 on it as well, but no luck. Is it possible to buy a new set screw if I damage this one?
I might try to cut off the plastic parts of the rotor and see if I can get the screw off then.
i would try to find the set screw first before you destroy the one you have.. as i understand it... it is very difficult to find that set screw.. i havent looked personally but someone told me that it is very difficult to find one.
hey alok.. i found a replacemnt setscrew online.. here is the link
http://www.autoatlanta.com/action.la...rds=10&-search
