Shop recommendation for PPI in Venice/Sarasota FL area
Can anyone recommend a good shop to have a PPI done in the Venice/Sarasota FL area?? I need to get this done pretty quickly.
Thanks all.
Thanks all.
Make sure the shop does a leak down and compression check it will give you and idea of what to come on the engine. Also they would check very easily the shape the timing belts and water pump is. Good luck with maybe your future car. Also if it doesn't meet your standards don't buy it there are tons of good cars around. I looked close to a year for mine and ended buying from someone I knew.
