Sunroof limit switch help...
My sunroof has never worked perfectly. Very tempormental switch (which has actually not been giving me any problems latley). The roof never moves into the correct position to lock (need to do it manually). Also the roof has never gone to its max tilt height. I noticed this at Hershey where most of the cars had the roofs tilted much higher than mine. Anyways i took the rear carpetting off and found that the two limit switches werent attached to anything. I also found a bracket, nut and screw..but im not sure how to reconnect everything correctly.
Ive tried looking for diagrams, but cant seem to find anything. Can anyone give me an idea as to how this goes back together?
Yea, i checked the articles on ClarksGarage and on Pelican, both had alot of information but none really had any detail about how everything is assembled. Its really not that big of a deal to fix, as everything still works. But it would be nice to get the roof to tilt a little more. I basically just need a picture of everything assembled.
rockfan, amazing. Thanks alot, i never would have thought to check on ebay. Looks like im missing one of the small screws, probably have to dig around the RC toolbox to find something that fits. Thanks alot!
Hi Duck (dangerous name in my language)
The connection s are on the yellow sticker of your own photo.
Color coding:
Switch #1
gr/sw is gray / black
sw/rt is black / read
Switch #2
sw = black
gn/rt is green / red
Switch #3
ge is yellow
ge/sw id yellow / black.
Check the switch first with an ohm meter: these switches are generic and the contacts may have a different position or number than shown on your sticker.
Takecare
Color coding:
Switch #1
Switch #2
sw = black
Switch #3
ge is yellow
Takecare
