Need help with wiring up Vitesse V-MAF+
So I’ve gotten the hardware installed and now I’m onto the wiring.
I hate wiring, but, im up for it.
I have two questions. What’s a good source for a 12v switched power source? Which fuse could I add to?
the second one is a bit more of an issue for me. I’m supposed to tap into the #9, #16, and #28 wires coming out of the DME. The thing is how do you tell which wires go to those pins in the wire loom plug? All the wires come out of the yellow plastic on the end and you can’t see where and which wires go to which pin?
